phdgolf
Nov 16, 2022Aspirant
Suggested setup for Verizon Fios Internet Only
Good day all, We are contemplating switching from Comcast Xfinity (phone, internet, cable) to Verizon Fios 1 Gig plan (internet only) or to the Comcast 1000 Mbps plan (internet only). We currently ...
- Nov 17, 2022
How big is your home? Thats also key.
Your modem already supports gigabit service. and if you buy from verizon, you have to use their ont/gateway.
So it really comes down to router.
Your R6260 is the one of the most basic of gigabit routers they make.
so it'll basically be worth it to upgrade to something with a little more speed/capability.
Or upgrade to something like a mesh system if you're wanting more coverage.
Nov 17, 2022Guru - Experienced User
Maybe upgrade the 6 series router to something newer like a RAX series router. You won't be able to sue the CM series modem on FIOS. FIOS uses completely different hardware. The ISP will most likely be providing this.
