Screwthis
Nov 11, 2016Aspirant
Support for c6300
Their support system does not work: I copied & pasted the serial #, and it came back "invalid" (multiple, multiple, multiple times). I typed in the serial #, eliminating the capital letters- same t...
clithes
Nov 13, 2016Prodigy
What is the problem, maybe this community will have the answer?
Screwthis
Nov 13, 2016Aspirant
Thanks for your reply. This post got posted in the wrong place, so I posted again in Cable Modems & Routers > Troubleshooting.
The problem: signal gets dropped intermitently, and varies from 0 > 140 mbps.
I took the 3 week old modem/router back to Best Buy- their return policy states I only had 15 days (I'll never go back).
So, I turned to Netgeat Support. I registered my device. Got an email confiming that- serial # included.
But when I have tried to engage Support, it will not take that serial #- keeps coming back, "invalid."
I posted here- like I said this post and one other.
Yours is the only reply, two days later. I thought for sure Support would chime in, but.....crickets.
- michaelkenwardNov 14, 2016Guru - Experienced User
Screwthis wrote:Yours is the only reply, two days later. I thought for sure Support would chime in, but.....crickets.
This place is mostly user-to-user, with some input from a small team of Netgear folks. The official support teams doesn't hang out here.
Have you checked the support section for your device?
C6300 | Product | Support | NETGEAR
- ScrewthisNov 14, 2016Aspirant
Yes, as stated above I cannot get through to Support because the site keeps saying my serial # is "invalid"- even when I copy & paste from their email confirming my registration!
I posted here and elsewhere hoping their "occasional" moderators would look into it.
By "support" I meant the link I provided, not the "official channels".
Did I follow the link?
I explained the moderators thing.
