khorning
Apr 16, 2019Aspirant
Support for R6080 Constantly Losing Connection
Our internet constantly has connection issues it disconnects and we lose wifi. Comcast has been out here umpteen times and nothing has been fixed. They say it's a router issue. We have had the router...
Apr 17, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
khorning wrote:
Our internet constantly has connection issues it disconnects and we lose wifi. Comcast has been out here umpteen times and nothing has been fixed. They say it's a router issue. We have had the router replaced. Very irritated with Netgear's support and the router itself. The wifi freezes, cuts out, resets, does crazy things. Today it asked us to re-activate comcast on the router.
- khorningApr 22, 2019Aspirant
Firmware for netgear router: V1.0.0.40
Modem firmware: V 1.1 TC-7610 TP Link checked download page and no updates are available.
Here is the tp link system log.
- plemansApr 22, 2019Guru - Experienced User
If its a problem with the router FURRYe38 was correct in the forum you should be posting in.
If its the modem, you should be contacting tp-link about it since its one of theirs.
If its the connection to the house, thats on your ISP.
I will say, you have quite frequent "Resetting the cable modem due to docsDevResetNow " those usually originate from your ISP resetting your device whether due do updates, the CMTs detecting problems, the device being reset (either by your or by itself d/t problems).
You said you replaced the router and continue to have the same problems. If you replace something and the problem continues, it usually isn't that device.
Yes Netgear sent a new router under warranty. The connection directly to the modem never seems to have any issues, only the router where when we connect we consistantly get lagged or slow speeds or ddropped connections. The calls in and resets are with our ISP since I have to call at least once a week to reset it.
