Perky1970
May 02, 2025Initiate
Switch from megahertz to 2.4 MHz
How do I switch from 5 MHz to 2.4 MHz on my router
May 03, 2025Guru - Experienced User
What router do you have?
Tough to give any instructions without knowing what device is it.
- Perky1970May 03, 2025InitiateHello my model is Nighthawk CV7000v2. Thanks for reply
- plemansMay 03, 2025Guru - Experienced User
The C7000 doesn't have smart connect (combines the 2.4ghz and 5ghz signal into one). So it should be as simple as having the device choose the other ssid for the 5ghz.
You can log into your router and check to see what you named the 5ghz ssid
