goobledegook
Jan 09, 2025Aspirant
Switched from CM3000 to CAX80 and it destroyed upload/download speeds
So I recently moved to Benicia, CA and signed up for the 2Gbps download 300Mbps upload package Xfinity offers. At first I got the CM3000 just missing the fact that it only supported 1Gbps but ran a s...
goobledegook
Jan 12, 2025Aspirant
I appreciate the reply, however, CM3000 works "ok" as in great upload speed, but not getting the full 2Gbps download speed. Ran it against several servers close to me and it seems consistent no matter time of day or day of week.
My main issue is with the CAX80 which I'm returning. Using the same cables (other than the power adapter of course, hehe, I'm of course using the one that came with the CAX80), I'm getting 60x slower upload speeds while slower download speeds than the CM3000. I can understand the coax needing an attenuator, but that would not explain just getting 5Mbps upload compared to 400Mbps+ consistently since it's obviously capable of downloading at a much higher speed (~700Mbps, which is a lot lower than the CM3000 since I'm on a 2Gbps line, although I'm "only" getting 1.2Gbps on the CM3000).
For these reasons I'm returning the CAX80. I have asked Xfinity to send me a rental modem/router combo to see if I'm getting the speeds that my plan is supposed to give me and if it does, I'll return the CM3000 as well.
Appreciate your attempt to help tho.
jay_w
Jan 12, 2025Apprentice
I have a few more suggestions, I’ll write them down when I’m back at the house in a few hours. I spent weeks tinkering with my setup, different splitters, etc.
But in the meanwhile what WiFi router are you using with the CM3000?
I ask because the CM3000 is the best on the market that I know of, and I am getting 2gb all the way through to the router with the same modem.
- goobledegookJan 12, 2025Aspirant
That would be great, thank you. To answer your question, just temporarily I'm using a switch (Nicgiga S100-0800T) while testing just to make sure there's no interference from the router.
- jay_wJan 13, 2025ApprenticeLooking at your logs. You have quite a few errors there, but I go through periods of high errors and then sometimes weeks without a single error. This is almost always the Xfinity side but their support script is to blame the customer and tell them they need Xfinity hardware… which I think probably just hides the errors
Either way, let’s make sure we didn’t miss a bottleneck.
I’m assuming since you’re using a switch, you must be testing over a cable through a PC.
The uplink port on the switch is 2.5 or better I hope? You can also check the actual uplink connection speed through the switch if it has a managed UI. Otherwise this would bottleneck your connection.
Also, you should be using a CAT 6 or better cable. If not a shielded cable ensure there are no power cords crossed over the cable.
Also your switch should be at least 6 inches away from the modem to rule out EM interference.
If you’re not sure, then you can also try to plug directly into the back of the modem from your PC.
Next. Your PC should have a multi-gig connection to the switch. The standard is 1gb assuming your PC has 10gb?
The focus would be your COAX coming in from Xfinity. As others have mentioned downstream signal power should be between -10 and +10.
Your numbers are not horrible, only slightly out of spec. For my numbers, I landed on 7.x dbmv power download with 44 db SNR… and then 4 channels locked for upload with 41 dbmv power.
Xfinity lines are usually a little hot 9-12 dbmv coming from the street junction. Because they anticipate you will have 1 or 2 splitters.
My setup looks like this > Xfinity cable > MOCA filter > 2 way Amphenol splitter. Then from the splitter, I have one cable going to the modem without any attenuators. The other is capped with a terminator
This splitter only reduces my power by 3.7db. I did this by design because the house has 3 cable lines running to rooms. These lines are not used because we stream everything so I disconnected them to reduce any back feeding of interference. If I choose to use them, I can use a second splitter off the first one with plenty of power left.
Alternatively I could have used a 3 way or 4 way splitter and reduced my power by 5.8 or 7.3db.
Since your upload power is good, I would not use an attenuator. I ran into to a problem with correctables when I did that. Instead I would focus on your splitters and signal quality..
What does your coax setup look like? How many splitters? Where is the MOCA filter? Are they very old?- goobledegookJan 13, 2025Aspirant
Thanks for the extensive list! Overall I'm happy with the CM3000, my reason for posting was because of the performance of the CAX80 that I wanted to try out since it's a Modem/Router/Wifi combo so I didn't have to use a separate router.
However, just some quick answers:- Cables I'm using are all CAT6 or CAT6e. I haven't but I'll make sure they aren't crossing over any power chords.
- Switch supports 10Gbase-T, 5GbE, 2.5GbE, and 1GbE speeds (Nicgiga S100-0800T)
- Switch is over 6 inches away
- And yep, tried going straight into my PC so the Switch wasn't a factor. I'll be doing this by default right now just to minimize any problems that doesn't have to do with either the CM3000 or if I try out the CAX80 again.
- My network port on my PC(s) are 10Gb yeah.
- No COAX splitter, all I'm using the COAX port is for the modem, nothing else. I did get an attenuator to try with the CAX80 like FURRYe38 recommended.
I got the 2Gbps plan mostly for the 400Mbps upload speed since I'm a game developer and work remotely from home. We run Perforce if you know what that is (where the game is "housed") so it really helps to have a higher upload speed when submitting assets.
I'll probably will still send back the CAX80 and just get a good router and use that with the CM3000 and my switch.Thanks for all the help!
