goobledegook
Jan 09, 2025Aspirant
Switched from CM3000 to CAX80 and it destroyed upload/download speeds
So I recently moved to Benicia, CA and signed up for the 2Gbps download 300Mbps upload package Xfinity offers. At first I got the CM3000 just missing the fact that it only supported 1Gbps but ran a s...
Jan 13, 2025Guru - Experienced User
Since the power is out of spec and your seeing Criticals when you had the CAX80 online:
Downstream Status: Poor
Downstream Power Level: Poor
This means the CAX80 is not getting good ISP signal on the line. Power is TOO HIGH and any criticals, errors or warnings in the event logs means there is signal issues on the ISP coax line. Too high power will eventually burn out the modem. So the CAX80 will not be working as designed. Also since you have the CM modem online now, the CM modem maybe seeing same issues.
All these would cause problem and lead to what your seeing.
Hope your CM3000 won't see problems.
Good Luck.
