ljones86
Jun 30, 2022Follower
T-Mobile Gateway kdv21 and Netgear c6300v2
I used a coax to ethernet adapter to connect my Netgear Nighthawk to the T-moblile Gateway. I wanted to use the Gateway as a modem and create a LAN via the Netgear NIghthawk. How do I get the Night...
Jun 30, 2022Guru - Experienced User
the coax to ethernet adapter won't work.
but you could try following this guide to try to make it an access point.
Can I use a C6300 cable modem without cable intern... - NETGEAR Communities
