Lodjuret's avatar
Lodjuret
Follower
Apr 11, 2019
Teamspeak random disconnects
Hey! Teamspeak disconnects me at which seems random. This problem
started occuring when I upgraded the router. Before that I've had no
such problems at all. The router I currently use is R6220.
Error in teamspeak:
<20:29:04> Failed to connect to server
<20:29:05> Trying to resolve hostname
<20:29:07> Trying to connect to server
After I'm disconnected the client tries to autoreconnect but does not work
until I've restarted the client or switch back and forth from another server.
The only fix that I've seen regarding this problem which I've gathered
from other threads is to turn off DMZ, which I only tried for troubleshoot reasons.
So heres what I've done so far:
1. 'Disable Port Scan and Dos Protection'
Done, nothing changed in terms of the disconnect or anything noticable.
2. 'Disable SIP ALG'
3. Port Forward 'Teamspeak 3'
Teamspeak 3 Client uses the whole range of ports randomly so can't test this
4. Updated the router to the latest firmware (V1.1.0.86_1.0.1)
No changes at all, still having the same errors.
5. Client Log from Teamspeak.
2019-03-23 18:19:03	ClientUI	Info	Connect status: Connecting
2019-03-23 18:19:03	PktHandler	Devel	Puzzle solve time: 10
2019-03-23 18:19:03	ClientUI	Info	Connect status: Connected
2019-03-23 18:19:03	ClientUI	Info	Connect status: Establishing connection
2019-03-23 18:19:03	ClientUI	Info	Connect status: Connection established
2019-03-23 18:19:03	PermManager	Info	Loading permissions from cache
2019-03-23 18:23:57		Info	tried to request user integration info without valid session
2019-03-23 18:33:59		Info	Memory usage: 110.66 MiB
2019-03-23 18:48:59		Info	Memory usage: 109.93 MiB
2019-03-23 19:03:59		Info	Memory usage: 109.97 MiB
2019-03-23 19:18:59		Info	Memory usage: 109.96 MiB
2019-03-23 19:27:40	PktHandler	Info	Dropping client 54 because of ping timeout 19 0 0
2019-03-23 19:27:40	SCHandler	Warning	Got command data while disconnected, dropping
2019-03-23 19:27:40	ClientUI	Info	Connect status: Disconnected
2019-03-23 19:27:40	ClientUI	Info	Connection lost, want autoreconnect = 1
2019-03-23 19:27:41	ClientUI	Info	Autoreconnecting
2019-03-23 19:27:41	ClientUI	Info	Connect to server: TEAMSPEAK_DOMAIN_NAME
2019-03-23 19:27:41	ClientUI	Info	Trying to resolve TEAMSPEAK_DOMAIN_NAME
2019-03-23 19:27:41	TSDNS	Info	A/AAAA DNS resolve successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0)
2019-03-23 19:27:41	TSDNS	Info	A/AAAA DNS resolve for possible TSDNS successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0)
2019-03-23 19:27:41	TSDNS	Info	A/AAAA DNS resolve for possible TSDNS successful, "gameservers.com" =(h: 108.61.13.173 p:0)
2019-03-23 19:27:41	TSDNS	Info	SRV DNS resolve unsuccessful, "_ts3._udp.TEAMSPEAK_DOMAIN_NAME" Domain name not found
2019-03-23 19:27:41	TSDNS	Info	SRV DNS resolve unsuccessful, "_tsdns._tcp.gameservers.com" DNS server returned answer with no data
2019-03-23 19:27:42	TSDNS	Info	TSDNS queried unsuccessfully TEAMSPEAK_IP_ADDRESS:41144
2019-03-23 19:27:42	TSDNS	Info	No TSDNS found
2019-03-23 19:27:42	TSDNS	Info	TSDNS queried unsuccessfully 108.61.13.173:41144
2019-03-23 19:27:42	ClientUI	Info	Lookup finished: ip=TEAMSPEAK_IP_ADDRESS port=9173 query=TEAMSPEAK_DOMAIN_NAME error=0
2019-03-23 19:27:42	ClientUI	Info	Resolve successful: TEAMSPEAK_IP_ADDRESS:9173
2019-03-23 19:27:42	ClientUI	Info	Initiating connection: TEAMSPEAK_IP_ADDRESS:9173
2019-03-23 19:27:42	ClientUI	Info	Connect status: Connecting
2019-03-23 19:27:47	ClientUI	Info	Connect status: Disconnected
2019-03-23 19:27:47	ClientUI	Info	Failed to connect to server, want autoreconnect = 1
2019-03-23 19:27:48	ClientUI	Info	Autoreconnecting
2019-03-23 19:27:48	ClientUI	Info	Connect to server: TEAMSPEAK_DOMAIN_NAME
2019-03-23 19:27:48	ClientUI	Info	Trying to resolve TEAMSPEAK_DOMAIN_NAME
_______________________________________________
2019-03-23 19:31:52	TSDNS	Info	A/AAAA DNS resolve successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0)
2019-03-23 19:31:52	TSDNS	Info	A/AAAA DNS resolve for possible TSDNS successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0)
2019-03-23 19:31:52	TSDNS	Info	A/AAAA DNS resolve for possible TSDNS successful, "gameservers.com" =(h: 108.61.13.173 p:0)
2019-03-23 19:31:52	TSDNS	Info	SRV DNS resolve unsuccessful, "_tsdns._tcp.gameservers.com" DNS server returned answer with no data
2019-03-23 19:31:52	TSDNS	Info	SRV DNS resolve unsuccessful, "_ts3._udp.TEAMSPEAK_DOMAIN_NAME" Domain name not found
2019-03-23 19:31:53	TSDNS	Info	TSDNS queried unsuccessfully TEAMSPEAK_IP_ADDRESS:41144
2019-03-23 19:31:53	TSDNS	Info	No TSDNS found
2019-03-23 19:31:54	TSDNS	Info	TSDNS queried unsuccessfully 108.61.13.173:41144
2019-03-23 19:31:54	TSDNS	Info	No TSDNS found
2019-03-23 19:31:54	ClientUI	Info	Lookup finished: ip=TEAMSPEAK_IP_ADDRESS port=9173 query=TEAMSPEAK_DOMAIN_NAME error=0
2019-03-23 19:31:54	ClientUI	Info	Resolve successful: TEAMSPEAK_IP_ADDRESS:9173
2019-03-23 19:31:54	ClientUI	Info	Initiating connection: TEAMSPEAK_IP_ADDRESS:9173
2019-03-23 19:31:54	ClientUI	Info	Connect status: Connecting
2019-03-23 19:31:59	ClientUI	Info	Connect status: Disconnected
2019-03-23 19:31:59	ClientUI	Info	Failed to connect to server, want autoreconnect = 1
6. Router Log.
[admin login] from source 192.168.1.19, Saturday, March 23,2019 19:32:16
[Time synchronized with NTP server time-g.netgear.com] Saturday, March 23,2019 19:27:53
[DoS attack: RST Scan] from source: 31.13.72.8:443, Saturday, March 23,2019 19:25:11
[DHCP IP: (192.168.1.5)] to MAC address F8:81:1A:51:88:97, Saturday, March 23,2019 19:18:06
[DoS attack: RST Scan] from source: 31.13.72.53:443, Saturday, March 23,2019 19:00:08
[DoS attack: RST Scan] from source: 31.13.72.36:443, Saturday, March 23,2019 18:59:20
[DHCP IP: (192.168.1.15)] to MAC address 00:17:88:AC:71:8C, Saturday, March 23,2019 18:47:58
[DHCP IP: (192.168.1.13)] to MAC address A0:C9:A0:D9:41:E7, Saturday, March 23,2019 18:45:19
[DoS attack: RST Scan] from source: 31.13.72.53:443, Saturday, March 23,2019 18:42:22
[DHCP IP: (192.168.1.12)] to MAC address 80:4E:81:AE:7D:B5, Saturday, March 23,2019 18:38:22
7. Turn off DMZ
Done and the error does not occur when running like this. But I won't be able to
run with DMZ off on the long run.
Any ideas for fixes regarding this error except for turning off DMZ and/or switching to OpenWRT?
