Bricked1234
Feb 24, 2023Aspirant
TFTP program reset CAX30
Hi I have attempted the TFTF fix, has not fixed the problem but noted a few things if anyone worked or has feedback. General note When I reset the router and the 2 ethernet cable light turns o...
Feb 25, 2023Guru - Experienced User
Seems like your unit is in a full on bad state.
Please make contact with the forum moderators so they can help you from here on out:
