RichardRO
Dec 06, 2020Aspirant
The best cable modem for XR1000
I would like to know if a CM2000 would be a good match for my XR1000. Or if I should choose a different model. My ISP is Spectrum Los Angeles. Thank you.
1 Reply
NGs CM1000 would be best since the XR1000 doesn't support a 2.5Gb WAN port or support LAG, which the CM200 support a 2.5Gb WAN port. A CM1100 would be good however this modem support LAG. So the CM1000 would be best fit. First contact your ISP to ensure what modems are supported by your ISP.
