AlwaysConfused
Dec 04, 2020Tutor
The channels to use the internet are locked
"The channels to use the internet are locked" says the Netgear customer service rep. Granted the person was not a technician and couldn't offer me more than that (I am guessing they are following som...
Dec 04, 2020Guru - Experienced User
Your signal levels are a little high. not bad just a little over.
You won't see locked ofdma upstream channels.
Are you using port aggregation on the cm1200?
I've seen in the past issues with port aggregation causing decreased speeds after 12-24 hours.
AlwaysConfused
Dec 05, 2020Tutor
Thanks for the response. I have selected Ethernet Port Aggregation Status and rebooted the device. However, upon looking at the status (see attached) it is saying it is inactive. Is that ok? Should I try a hard reboot (unplug the system rather letting the software to reboot it)?
After doing that I have cleared the logs to see if the issue comes back.
Will respond back. Thanks!
Edit: Forgotten to tell you about your inquiry about the high levels. The Xfinity tech said the same thing that the line coming into the home is positive when usually they see it as a negative value. Because it is strong they originaly put a damper (my term as I don't know what's its called) to lower the power levels (again my term as I am trying to understand this all). The Tech then removed that damper thingy and that's why you're seeing it high. Should I ask them to put that device back in to lower it?
- plemansDec 05, 2020Guru - Experienced User
Leave it.
Switch your port aggregation to disabled.
Then make sure only 1 device is plugged into the cm1200 and have it only connected to port 1.
Then reboot the modem and use it
- AlwaysConfusedDec 05, 2020Tutor
Have done that. So basically I have gone back to how my modem was originally configured when I was having the issue. Still doesn't address what the Netgear rep was saying that the channels to use the internet are locked.
Does this mean I have a defective modem? I will do a wait and see approach with these changes. Not going to lie, but I am doubtful this has addressed the issue. (Don't mind being proven wrong as I really want my modem to work as it once did).
The channels are supposed to be locked.
When they aren't, it means they aren't connecting back to the ISP.
