markaaron
May 28, 2022Aspirant
The mysterious Netgear Nighthawk CM1150V
SERVICE. DEVICES. OPERATING SYSTEM Internet Service: Xfinity 500 Mbps Modem: Netgear Nighthawk Cable Modem with Voice (CM1150V) Laptop 1: Dell Latitude E7440 Laptop 2: Dell Precision 7760 Ca...
May 29, 2022Guru - Experienced User
Kitsap is correct. you need a router.
The problem is xfinity. They only assign 1 public ip address per account. (unless you pay extra for more or have a business grade account).
Usually the procedure you followed works. But the problem is, sometimes it takes xfinity a while to reassign that public ip address. Again, its usually minutes but I've seen it take upwards of 30 minutes before during troubleshooting.
Buying a cheap gigabit router and just disabling its wifi (or leave it enabled) would fix your issue as you could connect as many devices as you wanted. You could get a generation or 2 old router off amazon or craigslist/fleabay for pretty cheap and you wouldn't have to fight the issue you're having.
markaaron
May 29, 2022Aspirant
Hello, plemans. Thanks for your reply.
I purchased a Netgear 8-Port Gigabit Ethernet Unmanaged Switch (GS308). My original idea was this configuration:
Xfinity > Netgear CM1150V cable modem > Netgear Ethernet Switch > Dell Precision and Dell Latitude
That configuration doesn't work and, as I described above, bypassing the GS308 ethernet switch and connecting directly to the Latitude doesn't work either. I'm still not clear about why the Precision connects, but not the Latitude. But, at this point, I just want to get the Latitude connected. (It will serve as a backup).
Could you, please, provide a couple of router recommendations? The most important feature, for me, is a physical, external switch that would allow me to turn off the wireless radios (not just the SSID broadcast), without interrupting my hardwired connection to the internet. I do not want to access router settings via the internet to accomplish this.
I'm not concerned about the cost of the router. This is for my work, and it's important to have a reliable, fast and stable connection. My current Xfinity service is 500 Mbps, but I might upgrade the speed at some point.
Thanks again.
- FURRYe38May 29, 2022Guru - Experienced User
FYI, the CM series of modems DO NOT have a built in router.
Xfinity > Netgear CM1150V cable modem > Netgear Ethernet Switch > Dell Precision and Dell Latitude< This will NOT work.
Xfinity > Netgear CM1150V cable modem >External Wifi Router> Netgear Ethernet Switch > Dell Precision and Dell Latitude< Will work.
- markaaronMay 29, 2022Aspirant
Thanks, FURRYe38. You Gurus are good. đ
Can you recommend a good router? As I mentioned above, the most important feature, for me, is a physical, external switch that would allow me to turn off the wireless radios (not just the SSID broadcast) without interrupting my hardwired connection to the internet.
I receive a very large amount of fast, real-time streaming data during my work. The Precision has an i7 and 64GB RAM. And, I'm running two external monitors with a multiple monitor dock.
Hmmm, Possible NGs RAX series might have something, like a RAX40 series.
Another suggestion would be to have just a wired router only and then connect a wireless system in AP mode to the router. Then you might have more controls.
You might reivew this forum and maybe post to users on there experiences with there RAX routers here:
microchip8 Would be one to approach.
