WalterEH
Sep 26, 2023Aspirant
The router will not fully restore after internet service is disrupted and restored.
I have now had the same problem with two different CAX80's at two different homes. The router will not fully restore after internet service is disrupted and restored. Currently I am trying to fix o...
WalterEH
Sep 28, 2023Aspirant
I did some more digging and found a solution; sharing, in case anyone else has this problem.
I read reports from some others that there have been instances where the CAX80, upon being reset following an internet outage, reset the Wifi SSID to "Broadcom." I was able to access the router remotely using the Nighthawk app, which would show a HomeAssistant server (hard-wired) as connected, but no Wifi devices. I checked, and it showed that the SSID's had been reset to "Broadcom." I was able, using the Nighthawk app, to reset the Wifi SSID and passwords to what they should be; and following a reset, the Wifi devices were able to connect once again.
While this workaround does solve the problem, it's still a bug (something for Netgear to look into) that the restoration of an internet outage can cause the SSID to change to "Broadcom."
Sep 29, 2023Guru - Experienced User
We'd need the requested information that was asked for.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
