shar2649
Nov 25, 2017Aspirant
This old woman needs help
I am being told by Comcast that I need to purchase a new model. I currently have a Surfboard 6121 connected to a Netgear Everywhere router running thru an Ooma phone. All of this is connected to 5...
shar2649
Nov 27, 2017Aspirant
Could you please explain that those mean...
16x4, 24x8, 32x8 or D3.1 modems. And I guess also which of the suggested modems would work?
vkdelta
Nov 27, 2017NETGEAR Employee Retired
16, 24, 32, etc are number of downstream channels
4, 8, etc as number of upstream channels
- vkdeltaNov 27, 2017NETGEAR Employee Retired
If you are short on budget, just get a CM500 from amazon or nearest store.
- shar2649Nov 28, 2017Aspirant
One of the modems suggested is CM600, also CM700, also CM1000....but I am unaware of whether these would be good.
- CharliesTheManDec 03, 2017AspirantSo from what it sounds like is they are upgrading equipment to use more bonded channels. Cable modems have channels that are like lanes on a highway, used to be one lane each way. Then they went to multiple lanes to transmit so much bandwidth.
24x8 for instance is 24 bonded channels (lanes on one side of the highway down) and 8 bonded channels for upload bandwidth.
From posts above, I see that your surfboard is 4x4 and Comcast is probably upgrading to something like 24x8 or 16x4.
The CM600 or CM700 should work fine.
If you can tell us what your internet speed package is, like how fast your download speed and upload speed is, we can tell you better.
It should be a number like 200 mbps download speed, 10 mbps upload speed. Or 1000 mbps download speed (this is gigabit and really fast) or anything in between.
Also, can you ask Comcast what the requirements for the modem is? You can ask this question directly, if they can't answer it ask to speak to someone that can. Maybe try online chat for support if they offer it.
Ask this:
Do you need DOCSIS 3.0 or DOCSIS 3.1? How many channels upstream and downstream?
DOCSIS is just a cable modem standard, and some service providers are going to DOCSIS 3.1 while others are skipping it, Comcast should be able to tell you which standard you need, that will help you avoid wasting money on equipment you don't need.
Don't worry you're more competent than most "help this old woman understand" types of people. The service providers usually don't know what they're telling you to buy, and confusion = dollars to them.
