illzoni
Nov 01, 2023Aspirant
Time to Replace CM1100?
Xfinity tells me my modem, CM1100, is 3 years old and is causing connection issues with my internet service. Does this seem accurate? DOCSIS® 3.1 Cable Modem (CM1100)
Nov 01, 2023Guru - Experienced User
No. Someone at the ISP is trying to get you to spend money elsewhere.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
