illzoni
Nov 01, 2023Aspirant
Time to Replace CM1100?
Xfinity tells me my modem, CM1100, is 3 years old and is causing connection issues with my internet service. Does this seem accurate? DOCSIS® 3.1 Cable Modem (CM1100)
illzoni
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 543000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
illzoni
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream OFDM Channels</tabindex=-1> | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Current System Time: Wed Nov 01 15:57:15 2023 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
| System Up Time: 0:55:30 |
- illzoniNov 01, 2023Aspirant
Ok, I think I was able to post what was requested.
Looking forward to sorting this out.
Thanks!
- FURRYe38Nov 02, 2023Guru - Experienced User
Please post the entire data on the connections page along with the data from the events log page.
You can copy and paste into a word doc then export to PDF file than attach to your next post if that helps.
- illzoniNov 02, 2023Aspirant
Here's the connection info.
