Finghard
Jul 26, 2020Tutor
Time to update my system
Hi all, I would like a wired setup with a WiFi access point. I would like a wired router with all the bells and whistles of the xr700 or xrm500 with more ports and then a hard wired WiFi point put in ...
Finghard
Jul 26, 2020Tutor
At the moment I have 3 ports of my hub feeding three rooms which each have an 8 port switch . The fourth port feeds my sonos mesh . Of my computer room switch I feed two other rooms that also have 8 port switches . Everything will go through the hub and I require a managed hub/switch that works with the new nighthawk / duma system
Finghard
Jul 26, 2020Tutor
Most broadband accesses the house in the worst place for wifi outside wall corner room. I find it strange that my ideal setup up hasn't been contemplated before an 8 port non wireless, managed hub with an one of the ports specifically designates for wifi access point (One cat wire to the best position for your wifi AP) a master and slave setup
