rslobodian
Oct 02, 2017Follower
Timeing out problem
Upgrade my Comcast service from 120 Mbps to 235 Mbps. My C 6300 says transfer rate is 144 Mbps Is this why I have time out problems and lots of 'hesitations'? Netgear says C6300 will do up to 680 ...
DarrenM
Oct 04, 2017Sr. NETGEAR Moderator
Hello Rslobodian
You may need to check with your ISP it may need a modem that has more downstream channels in order to get higher speeds. As for the timeouts what are you seeing in the modem logs?
DarrenM
