imikus
Apr 02, 2020Follower
To keep or not to keep the CM 600
Hey, New to the forum but not Netgear. Wanted to get an opinion on wether I should keep my new modem CM 600 or go back to my old one which is a CM 400. Wifi network is good with 70mb download speed...
Apr 03, 2020Guru - Experienced User
not a lot of benefit if you don't plan on upgrading your speed.
If you do plan on upgrading shortly, then yes there is a benefit.
I say shortly because docsis 3.1 devices have been coming down in cost and they're capable of gigabit. If your not upgrading shortly, I'd return the cm600 as it won't benefit you any until you up your speed.
