pratapb
Mar 29, 2022Initiate
Trade In Option
Hi, I have two cable Modem Router (C7800) and the new place we moved they are having fiber optics so I would like to go for the fiber connection. I would love to upgrade to a mesh routers but if ...
Mar 30, 2022Guru - Experienced User
there isn't.
Your best bet it to sell them on a 3rd party site or hold onto one in case you move back
- pratapbMar 30, 2022Initiate
Thank you for your response. Yes, after posting I realized there isn't and I hope somebody from netgear takes a look and start offering that option.
Pratap
- FURRYe38Mar 30, 2022Guru - Experienced User
NG doesn't have any kind of trade in program. As suggested, you'll need to offer your modem up for sale where ever you can find a place to sell it. Places like fleabay, amazon or craigslist.
Good Luck.
- plemansMar 30, 2022Guru - Experienced User
You can try using it as a sort of access point. Its a work around method since it doesn't support just a router mode but I've seen it work for some users.
