Raymond818
Feb 07, 2020Aspirant
Trouble logging into routerlogin.net
I have a Netgear C6300 wifi cable modem router. Firmware Version V2.01.26. The pc is connected to the modem using a lan cable. In Windows I can access it using http://routerlogin.net with IE and Ch...
Feb 08, 2020Guru - Experienced User
How about 192.168.0.1? This work?
Be sure to clear ALL browser caches and exit then relaunch the browser.
- Raymond818Feb 08, 2020Aspirant
Thanks for the reply.
Tried clearing cache, rebooting. Tried my laptop (hard wired) (linux). Same results.
http://192.168.1.1will bring up the login screen.
will not connect
- FURRYe38Feb 10, 2020Guru - Experienced User
And if you factory reset the modem with a wired PC connected to the modem and walk thru the setup wizard?
- KevinMarleeFeb 13, 2020Aspirant
Raymond818 wrote:Thanks for the reply.
will not connect
Generally if routerlogin.com/net don't work, you will want to factory reset your router. You will find a small RESET button at back of your router press it for few seconds until the lights start blinking. It will reset the router to its default settings so any manual configurations will be reverted. Then try using the 192.168.1.1 or 192.168.0.1 IP Addresses as suggested by Raymond818. It should be fine, let me know if it fixes your issue.
