Raymond818
Feb 07, 2020Aspirant
Trouble logging into routerlogin.net
I have a Netgear C6300 wifi cable modem router. Firmware Version V2.01.26. The pc is connected to the modem using a lan cable. In Windows I can access it using http://routerlogin.net with IE and Ch...
Raymond818
Feb 08, 2020Aspirant
Thanks for the reply.
Tried clearing cache, rebooting. Tried my laptop (hard wired) (linux). Same results.
http://192.168.1.1
will bring up the login screen.
will not connect
Feb 10, 2020Guru - Experienced User
And if you factory reset the modem with a wired PC connected to the modem and walk thru the setup wizard?
