SCSM
Apr 22, 2025Aspirant
Trouble with 5G Band on Nighthawk AC3200 WiFi Cable Modem Router (C7800)
My modem/router LED light shows that the 5G radio is on - sometimes solid and other times flashing intermittently. My devices all show that the 5G band network is available. The same is true for th...
SCSM
Apr 23, 2025Aspirant
I am not exactly a computer tech guru. I don't recall which channels the two were set up on but I do believe that they were both set to the same channel. I have no idea how to tell if the Smart Conect is enabled or disabled but can follow most instructions to check if providerd. I was able to find that Sparklight had pushed the most current firmware version to my modem/router.
If I try to do a factory reset followed by a fresh set up will that cause the Firmware version to revert to an older version? I only ask because I learned through research on this forum along with verifying on the website that the firmware updates have to be pushed by ISP providers who don't like to do it because of associated cost.
Your assistance if greatly appreciated, thank you.
Apr 23, 2025Guru - Experienced User
No, Factory resets do not revert FW updates.
Can check for Wifi configurations on the modems web page:
https://kb.netgear.com/980/How-do-I-log-in-to-my-NETGEAR-home-router
When doing a factory reset, use a PC to set it up:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
