JohnDamascus
Apr 19, 2018Aspirant
Trying to change DNS settings, will not apply or save them
Hello all, I'm trying to change DNS settings (generally for spoof location streaming) in the C6300, and I have done this on other systems with different modems. When I try to change DNS for a par...
vkdelta
Apr 20, 2018NETGEAR Employee Retired
can you please try entering 3rd server or if you dont have 3rd one, just copy 2nd one exactly in 3rd one.
bastapastas
May 03, 2018Aspirant
- DarrenMMay 08, 2018Sr. NETGEAR Moderator
Hello bastaoastas
Do you have the parental controls enabled on the router if so try to disable them and use the workaround above as the open DNS should still filter websites.DarrenM
- bastapastasMay 08, 2018Aspirant
Although it does show as "enabled", the setting is set to "none" in the parental filters. There does not appear to be any toggle to disable it altogether.
- DarrenMMay 09, 2018Sr. NETGEAR Moderator
You will need to disable them in the Netgear genie app.
DarrenM
