Motown22
Feb 18, 2025Follower
Trying to Disable Router on AC 1900 Cable Modem
I am attempting to disable the router, so I can add a deco tp-link AXE5300 mesh system for greater coverage. When I attempt to log in to the router through routerlogin.net or.com, I'm told I'm not connected to my router, so I can't log in. Clearly, I'm connected to my router, as I'm able to get to the Netgear site along with all other internet sites.
So, is there a workaround or is it ok to connect the mesh system without disabling my Netgear router? Thanks, in advance, for any advice/solutions.
1 Reply
here's the guide once you log in through the browser.
https://kb.netgear.com/27191/How-do-I-set-my-NETGEAR-cable-modem-router-to-function-as-a-modem-only
