wifi-problems
Jun 27, 2022Follower
Trying to get a Netgear C7800 to work without cable internet
I live in a remote area, and the internet we have is provided via LTE signal to a BEC Airconnect 8110 Router, which then provides the wifi to our house. I had a Netgear C7800 in the garage and want to see if I can use it in addition to the Airconnect Router to provide better wifi to the house. So Airconnect receives the LTE signal, but then I want the C7800 to provide the wifi (attempting to do so via ethernet from the Airconnect)
I can only get ethernet out of the Airconnect, so I can't give the C7800 the coaxial cable that it usually receives. Any thoughts on ways to make this work? or is it even possible?
1 Reply
there used to be a work around to make it function as a sort of access point but I've heard a report or 2 of them auto-rebooting when they don't detect a coax signal. Not sure if that'd be the case with yours so you can try the work around.
Follow this guide for the c6300. should still be the same process.
