dealio
Sep 27, 2024Aspirant
Trying to set up static ip
I have a netgear with the netgear genie access portal and I tried to set up static ip everything is saying signal and function is working but still can’t get some devices to load connect to the router...
- Sep 27, 2024
Only if you want to have devices have a IP address that doesn't change.
For WAN side IP addressing, you'll need to consult with your ISP.
Sep 27, 2024Guru - Experienced User
What NG product are you referring too?
Something to maybe contact the ISP about?
dealio
N600 Wi-Fi DOCSIS 3.0 Cable Modem Router (C3700)
That modem doesn’t let me block external ip from sending flood pings and scans. I’m trying to set a different ip so they don’t have easy access but the connection isn’t full even when the signal says it’s working. My ISP can’t do anything about changing ip I’m wondering if they can give access to the static ip on my router that might make the connection be full.
