dealio
Sep 27, 2024Aspirant
Trying to set up static ip
I have a netgear with the netgear genie access portal and I tried to set up static ip everything is saying signal and function is working but still can’t get some devices to load connect to the router...
- Sep 27, 2024
Only if you want to have devices have a IP address that doesn't change.
For WAN side IP addressing, you'll need to consult with your ISP.
