carlvanwormer
Mar 20, 2024Apprentice
Trying to view eMTA Event Log causes reset on my CM2050V modem
While logged in to the local web interface to my Nighthawk CM2050V modem, selecting the Advanced eMTA Event Log causes a modem reset after about 10 seconds. I don’t think this is normal, but I thoug...
Miked2
Mar 21, 2024Apprentice
I am on Hardware Version 1.01 Cable Firmware Version V2.01.03. And trying to open the eMTA event log causes the modem to reboot every time. This has persisted after modem reinitialization. Glad it is not just me...
- carlvanwormerMar 21, 2024Apprentice
This is great to hear! I will try to contact Netgear again to see if I can get access to more information about this condition. I'm past the 90 days of free tech support, but I'll see if I can weasel my way into support without paying the $60 they asked for last time.
Thanks,
Carl- carlvanwormerMar 21, 2024Apprentice
I called Netgear again and was able to gather more "free" information from the tech (who really wanted me to buy the additional tech support subscription). He wanted to prompt me through a reset and I told him I had already used the web interface reset, the power-cycle reset, and the hold-reset-button-down-for-7-seconds reset (from the online documents. He said I needed to do a 90-second shock reset, consisting of holding down the reset button with power-on for 30 seconds, continue holding down the reset button with power-off for 30 seconds, continue holding down the reset button for 30 more seconds while reapplying power. After this process, I should use the local user interface to set up the modem (no details given) and then contact my ISP to have the current software downloaded to me again. I'm not home right now, so I'll try this process when I get home tonight.
- Miked2Mar 21, 2024Apprentice
OK - Pls let me know if this works.
Thanks
