carlvanwormer
Mar 20, 2024Apprentice
Trying to view eMTA Event Log causes reset on my CM2050V modem
While logged in to the local web interface to my Nighthawk CM2050V modem, selecting the Advanced eMTA Event Log causes a modem reset after about 10 seconds. I donât think this is normal, but I thoug...
carlvanwormer
Mar 21, 2024Apprentice
I called Netgear again and was able to gather more "free" information from the tech (who really wanted me to buy the additional tech support subscription). He wanted to prompt me through a reset and I told him I had already used the web interface reset, the power-cycle reset, and the hold-reset-button-down-for-7-seconds reset (from the online documents. He said I needed to do a 90-second shock reset, consisting of holding down the reset button with power-on for 30 seconds, continue holding down the reset button with power-off for 30 seconds, continue holding down the reset button for 30 more seconds while reapplying power. After this process, I should use the local user interface to set up the modem (no details given) and then contact my ISP to have the current software downloaded to me again. I'm not home right now, so I'll try this process when I get home tonight.
carlvanwormer
responding to Miked2 (https://community.netgear.com/t5/user/viewprofilepage/user-id/312707đ
The Netgear tech I talked to did not get excited about the possibility that another CM2050V user has a similar reset problem. Would you have interest in contacting Netgear to see how they respond to your problem (which seems to be a duplicate of my problem)? If so, you may want to reference my case number (48116846) to see if you can get some related action. Maybe if they see that this reset problem is not an isolated incident, we might get some action. Any help would be appreciated.
Thanks,
Carl
- KitsapMar 21, 2024Master
For background information, here is one where the eMTA log works.
Detail pages attached.
- carlvanwormerMar 21, 2024Apprentice
OK, so it seems that some CM2050V units don't reset for the eMTA log viewing. Does anybody have any suggestions or guesses as to how to troubleshoot this issue?
thanks,
Carl
- FURRYe38Mar 21, 2024Guru - Experienced User
What browser are you using? Happens with other browsers? MS Edge, Firefox or Opera?
Happens with a different PC?
Does this happen if you directly connect a wired PC to the back of the CM modem with out the external router connected?
