carlvanwormer
Mar 20, 2024Apprentice
Trying to view eMTA Event Log causes reset on my CM2050V modem
While logged in to the local web interface to my Nighthawk CM2050V modem, selecting the Advanced eMTA Event Log causes a modem reset after about 10 seconds. I don’t think this is normal, but I thoug...
Mar 21, 2024Guru - Experienced User
So, for users seeing this issue, NG is aware and is working on it. Should be fixed in next certified FW update with the ISP.
NG recommends avoiding accessing the logs for now to avoid this issue.
Please be patient while NG works on this.
Miked2
Mar 21, 2024Apprentice
Pardon me for being harsh...
But I have been quite patient waiting for my $300 modem to work with Comcast as it should! Mostly because if we want Voice support there are no choices. So, when will this all (next tier speed and eMta Log) be fixed? Are we sure the upload speed issue is only firmware and not a hardware flaw?
However, I do appreciate the update.
Thanks!
