carlvanwormer
Mar 20, 2024Apprentice
Trying to view eMTA Event Log causes reset on my CM2050V modem
While logged in to the local web interface to my Nighthawk CM2050V modem, selecting the Advanced eMTA Event Log causes a modem reset after about 10 seconds. I donât think this is normal, but I thoug...
patreeek
Mar 25, 2024Tutor
I can confirm that this happens on my modem as well. Viewing the event log sometimes causes the modem to reboot.
- Miked2Mar 25, 2024Apprentice
Me as well!
Is there some way to report issues to netgear, without paying for support?
- carlvanwormerMar 25, 2024Apprentice
When my system "always" reset when clicking on the eMTA Event Log button, I tried a direct connect to the modem from my laptop. That connection gave me the eMTA Event Log and after that, connection of my main computer through the router was able to load the eMTA Event Log without resets. After performing a "shock reset", the software had changed back to the V2.01.01 version and my eMTA Event Log requests started doing the resets again. My questions to you are "do you like to play" and "are you feeling lucky?"
Later,
Carl- Miked2Mar 25, 2024Apprentice
I have never felt lucky with NetGear products. I have had many and they always seem fluky. I bought this because for voice and high speed comcast data, this was the only choice, then it fell off the compatibility list đ
- KitsapMar 25, 2024Master
Did a power cord restart of my CM2050V this afternoon. The restart process took two passes to complete. When I logged in to the modem, firmware V2.01.01 had been re-installed. When I try to access the eMTA event log, the modem restarts. However, firmware V2.01.01 is still in place after the restart.
Have not tried to access the modem directly from a computer without a router in line.
