MiRad's avatar
MiRad
Follower
Jul 03, 2018
Turn off WMM
Hello. I need to turn off my WMM because I see suttering when I use Airplay between my Mac and Apple TV. I have read that this may solve the problem. I tried to use the user manual for N450, but there is no WMM in the menu. Is there anyone who has solved this issue? Thanks.
1 Reply
  • > [...] I tried to use the user manual for N450, but there is no WMM in
    > the menu. [...]
       Which "the user manual"?  Which "the menu"?  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.
       If there is no Setup > Wi-Fi Multimedia option (as described in the
    User Manual), then firmware updates may have changed the options.  Can
    you find anything about "Quality of Service" or "QoS", instead of "WMM"?
       A cable-TV ISP has complete control over the firmware of any
    modem(+router) on its network.  It's also possible that your ISP has
    disabled such features.
    > [...] I see suttering when I use Airplay between my Mac and Apple TV.
       Do both these devices use wireless connections to the modem+router?
    > [...] I have read [...]
       I've read things, too, some of which were more useful than others.
