LitteGratz
Nov 05, 2021Aspirant
Turn the Nighthawk CAX80 into a Modem only
CAX80 - Nighthawk® AX8/8-Stream WiFi 6 Cable Modem Router How do I set it up the CAX80 as just a Modem? My House is just to big and I want to do a Mesh Wifi system and use the unit as Modem only ...
- Nov 05, 2021I’ve got the CAX80, and I’m using the EAX80 extender. When connected to the CAX80, it can be set up as a mesh network. The EAX80 works quite well, and covers more than 3,000 square of my house with ease.
https://www.netgear.com/home/wifi/range-extenders/eax80/
LitteGratz
plemans Thanks for the suggestion.
So if I use an Orbi Mesh System I can set each unit into Access Point mode? I have used Orbi in the past and I do not remember that option.
Let me know if this is a question for a different forum.
Thanks
Richard1864
Nov 05, 2021Luminary
- LitteGratzNov 05, 2021Aspirant
Thanks Richard1864
Not sure how I missed seeing this item. I am very happy with the CAX80 and its Wi-Fi performance is very good as compared to what I have had in the past but it didn't do it with a 5,000 Sq Ft home, in some areas the signal was just week. Then add a couple gaming kids and you hear about it.
I will try this solution and since it is mesh I can always add 2 extenders if I need.
Rob
- Richard1864Nov 05, 2021LuminaryNo problem! :). I missed it too when I first got the CAX80, and then saw the EAX80 in Target of all places! Thought I’d give it a try, and I’ve been very pleased with it.
Now if I could just get my 19 month old kitten to stop eating Ethernet cables, it would be perfect.
