levelred
Nov 06, 2015Initiate
TWC + C3700
Why not publically relases the fix? I need this fixed! Instead searching and sending PM the fix should be listed publically! BTW can I have the fix. This is annoying!
remilia
Nov 08, 2015Tutor
TWC just came & they're blaming the slow speed to the C3700 router for slow speed. Is there a way to fix the slow internet connection? Please help, thank you.
- levelredNov 08, 2015Initiate
well TWC downgraded the firmware and seems to be working fine now!
- vkdeltaNov 09, 2015NETGEAR Employee Retired
yes, TWC seems to have downgraded quite a few users, looks like there was an interop issue with a headend equipment in some areas of deployment.
if you are still on new FW and seeing issue, can you please let us know asap.
- KingStNov 10, 2015Aspirant
Still awaiting TWC to push down the old firmware.. Not sure why its taking so long?
Any advice?
Thanks,
David
