levelred
Nov 06, 2015Initiate
TWC + C3700
Why not publically relases the fix? I need this fixed! Instead searching and sending PM the fix should be listed publically! BTW can I have the fix. This is annoying!
levelred
Nov 08, 2015Initiate
well TWC downgraded the firmware and seems to be working fine now!
vkdelta
Nov 09, 2015NETGEAR Employee Retired
yes, TWC seems to have downgraded quite a few users, looks like there was an interop issue with a headend equipment in some areas of deployment.
if you are still on new FW and seeing issue, can you please let us know asap.
- KingStNov 10, 2015Aspirant
Still awaiting TWC to push down the old firmware.. Not sure why its taking so long?
Any advice?
Thanks,
David
Any when TWC sent their tech on Friday he said it was a modem/router problem with Netgear and tried to sell me the TWC modem/router for $9 a month.. Finally got tWC to admit it was their firmware upgrade that is the problem.. But still haven't got the firmware downgrade from TWC, I'm out of business.....
- b_3xNov 10, 2015Aspirant
Same issue here for C3000, TWC says it is the customer owned modem issue, they don't take responsibility for pushing the update for the firmware.
i think it is better to buy a non-netgear modem, the fix will be instantly....
- remiliaNov 10, 2015Tutor
still experiencing slow internet speed, especially at night, i wonder why?? do you have some instructions on how to make changes on the firmware, since twc have since given up on helping. they gave me 2 options, rent from them at $8/mth or send someone. which they already did send someone over the weekend but as many of twc customers might have previously mentioned, can't really help much since we have netgear :(
