Angel_Guzman
Feb 19, 2024Tutor
Unable to activate WPS
Manually pressing the WPS does nothing as the manual states "The WPS LED blinks during this process and then lights solid." So I went and typed the IP address and logged into the router via a com...
Angel_Guzman
Feb 19, 2024Tutor
The reason i am stuck trying to use the WPS function is due to a Linksys re7000 series product prompting me to activate the WPS so it may connect
- plemansFeb 20, 2024Guru - Experienced User
You can setup the RE7000 with a browser. Sometimes that works better. Page 9 of their manual goes over that method. Tends to work well
https://downloads.linksys.com/downloads/userguide/RE7000_UG_International_20160906.pdf
Also, you didn't put what router you're trying to connect it to. Tough to help in that case.
- Angel_GuzmanFeb 20, 2024Tutor
Thank you for responding to my post.
Yeah i tried following the setup process using the browser but for some odd reason when i am asked to input a password so the extender may connect to my router wifi, the linksys extender fails to connect and tells me its the wrong password but ive already verified its the correct password. I can opt in for the wired connection from router to extender but i would not be able to connect my desktop to the internet wirelessly
Router is a cax30 ax6
What firmware is on the CAX30?
What security method (for wifi) are you using on the CAX30? WPA2, WPA3, or mixed mode WPA2/WPA3
