Angel_Guzman
Feb 19, 2024Tutor
Unable to activate WPS
Manually pressing the WPS does nothing as the manual states "The WPS LED blinks during this process and then lights solid." So I went and typed the IP address and logged into the router via a com...
michaelkenward
Feb 20, 2024Guru - Experienced User
You mean the WPS LED/Button does not flash?
Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- Angel_GuzmanFeb 20, 2024Tutor
Reply to: MichaelKenward
yeah its got a set of 4 LAN ports on the back its a cable modem/router combination.
Its the CAX30 Netgear night hawk AX6 AX2700
I'll provide the current firmware version as soon as i get home in a couple hours
