Angel_Guzman
Feb 19, 2024Tutor
Unable to activate WPS
Manually pressing the WPS does nothing as the manual states "The WPS LED blinks during this process and then lights solid." So I went and typed the IP address and logged into the router via a com...
Angel_Guzman
Feb 20, 2024Tutor
Thank you for responding to my post.
Yeah i tried following the setup process using the browser but for some odd reason when i am asked to input a password so the extender may connect to my router wifi, the linksys extender fails to connect and tells me its the wrong password but ive already verified its the correct password. I can opt in for the wired connection from router to extender but i would not be able to connect my desktop to the internet wirelessly
Router is a cax30 ax6
Feb 20, 2024Guru - Experienced User
What firmware is on the CAX30?
What security method (for wifi) are you using on the CAX30? WPA2, WPA3, or mixed mode WPA2/WPA3
