AKS2712
Apr 09, 2019Aspirant
Unable to be extend C3000 Netgear wifi network
I have purchased a new router and wanted to connect the new router to my device. But whenever I connect the new router, it doesn't get any signal. My device has modem + router, so I tried disabling m...
AKS2712
I followed below steps:
1. Put device in modem mode
2. Reboot the device
3. Internet work on the computer via LAN cable from the modem
4. Connected LAN cable from modem to the new router, but no single
not sure what to do.
antinode
Apr 09, 2019Guru
> my device. [...]
Is "my device" your C3000? Why? Do you want to replace the
router/wireless-network parts of the C3000 with the
router/wireless-network parts of the 5260CV, or did you want to keep the
router/wireless-network parts of the C3000, and use the 5260CV to extend
your wireless-network coverage, or what?
> [...] But whenever I connect the new router, [...]
"connect the new router" how, to what? Hint: If a device has
multiple Ethernet ports, then "connected to device" is not enough
detail.
> [...] it doesn't get any signal.
I don't know what that means to you. As usual, showing actual
actions with their actual results (error messages, LED indicators, ...)
can be more helpful than vague descriptions or interpretations.
> [...] My device has modem + router, so I tried disabling my router but
> it didn't work. [...]
"tried" or "didn't work" is not a useful problem description. It
does not say what you did. It does not say what happened when you did
it. See "As usual, [...]", above.
So, the C3000 is working in modem-only mode?
A Netgear forum may not be the best place to get advice on
configuring a Sagemcom 5260CV. Have you found any documentation (set-up
instructions, for example) for the 5260CV?
Is "device" your C3000?
Another possibility would be to leave the C3000 as a modem+router,
and configure the 5260CV as a wireless access point.
I'm not sure what you want to do, but getting a user manual for the
5260CV would seem to be a good way to start.
