DanQCR
Jan 07, 2022Star
Unable to connect to guest network on CAX80
Hi, I have turned on the guest network 2.4Ghz so I can have a dedicated 2.4 network for my security cameras. It all looks good on the configuration, but no devices can connect to it, not even a p...
Jan 07, 2022Guru - Experienced User
What firmware version is on it?
Have you tried changing the ssid and/or password?
Are you using wpa2 or wpa3?
- DanQCRJan 07, 2022StarLatest firmware. Yes, I changed the ssid along with the password and changed from wpa2 to wpa3 and other options including disabling the password completely, which is obviously not ideal, with no avail.
As soon as I have a couple minutes I’m gonna reset the whole thing and reprogram as suggested by some users. We’ll see what happens.
Thanks for your reply. 👍
