DanQCR
Jan 07, 2022Star
Unable to connect to guest network on CAX80
Hi, I have turned on the guest network 2.4Ghz so I can have a dedicated 2.4 network for my security cameras. It all looks good on the configuration, but no devices can connect to it, not even a p...
DanQCR
Jan 07, 2022Star
So. I reset the whole thing and now it seems to be working fine. Strange, because all setting are exactly the same as before. 🤷‍♂️
- plemansJan 07, 2022Guru - Experienced User
Glad you got it resolved!
If you mark it as solved, it might help the next person with this issue.
- DanQCRJan 07, 2022StarI’m gonna wait a couple days to gain some more inputs from the community and then I’ll mark it solved. We shouldn’t have to be resetting our devices every time we turn a feature on or off.
