Rancandyce
Jul 07, 2022Aspirant
Unable to connect to Nighthawk CAX80
Model is Nighthawk AX8 AX6000 I am unable to connect to the modem through the setup. The app directs me to plug in the modem and wait for it to power up. Then it says to connect to Netgear79 but it d...
Jul 07, 2022Guru - Experienced User
Are you able to connect if you hardwire in a computer/pc?
Did the wifi on/off button get hit? Push and hold it for 2 seconds
Rancandyce
I have two things hardlined into the modem/router and the network doesn't pop up. There are 2 buttons that don't have a symbols by them and unfortunately I do not have a manual.
- plemansJul 08, 2022Guru - Experienced User
Did you try a factory reset? Push and hold reset for 7-15 seconds while powered on
- RancandyceJul 15, 2022AspirantYes we've tried a factory reset and it still wasn't allowing me to connect to what was supposed to be Netgear97. It just wasn't popping up at all on my phone, laptop, or desktop. We are going to return in under warranty.
