Rancandyce
Jul 07, 2022Aspirant
Unable to connect to Nighthawk CAX80
Model is Nighthawk AX8 AX6000 I am unable to connect to the modem through the setup. The app directs me to plug in the modem and wait for it to power up. Then it says to connect to Netgear79 but it d...
Jul 07, 2022Guru - Experienced User
Are you able to connect if you hardwire in a computer/pc?
Did the wifi on/off button get hit? Push and hold it for 2 seconds
Rancandyce
Oops nevermind, the symbols are just really small on the button. I have pressed it and held for 2 seconds and nothing happened. There aren't any new symbols lighting up. So far the only LED's that are on are: power, upstream, downstream, and online.
