prasanth5reddy
Aug 23, 2019Follower
Unable to disable AP isolation
I am trying to connect my google home mini to wifi from this modem router, but it says to disable ap isolation. I have searched everywhere in the advanced section of netgear genie portal, but couldn't...
Aug 24, 2019Guru - Experienced User
Anything under Basic Tab/Wireless settings or Advanced Tab/Advanced Settings/Wireless Settings
Is your setup mobile device connected to the 5Ghz radio or the 2.4Ghz radio. If the 5Ghz radio is being used for the setup mobile device. Connect to the 2.4Ghz radio with your mobile phone/pad.
