jahnus
Dec 16, 2016Follower
Unable to extend the signal from my Nighthawk C7000
Hello, I am looking forward to the help!
I have been issues with my signal. I have a Nighthawk C7000 in the oposite side of my house, and I am using an airport base station + airport express to bring the signal back here, where I need it the most. The signal is so weak, and so intermitent. I am wondering if there is any steps I must take so these devices communicate better? Thank you in advance.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello jahnus
The best thing you can do is change the wireless channel on your routers wifi settings until you get the best signal. We have a android app called Netgear wifi analytics that can help find the best channel and there should be some similar apps on apple to do this.
DarrenM
