crosend
Mar 26, 2024Follower
Unable to get internet from Xfinity on CBR750
I installed a new Orbi CBR750 cable modem on Xfinity network. During the provisioning with Xfinity all 4 indicators on front of CBR750 were solid white. Xfinity said they could see my router and th...
Mar 27, 2024Guru - Experienced User
Glad you got it working. You can install the CBR using a wired PC and web browser as well:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Enjoy. 📡
