tobiasrubin
Dec 05, 2022Aspirant
Unable to log into CAX80 it reverts back to PwdRec
When I try to access the CAX80 at 192.168.1.1 it reverts back to 192.168.1.1/PwdRec_index.htm. The only way I can get rid of this is to reboot, but that becomes annoying over time. Any help would b...
Dec 05, 2022Guru - Experienced User
What FW version is loaded?
What browser are you using?
Be sure to clear out all browser caches AND any saved browser PW profiles for the modems URL address.
Try a different browser as well.
tobiasrubin
I have the latest FW.
Doesn't matter what browser is used.
Yes I tried clearing history, cache, etc.
Nothing seems to work but a reboot, and then in a week or so it happens again.
- FURRYe38Dec 05, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
I've not seen this with my CAX80 and using MS Edge or Opera. I did ensure that the password manager for the browsers were cleared one time that I tried to log in with a browser that was using a incorrect saved PW. Once I cleared this, have not seen this again.
- tobiasrubinDec 05, 2022AspirantYes I have performed a complete factory reset and eventually the problem comes.
