tobiasrubin
Dec 05, 2022Aspirant
Unable to log into CAX80 it reverts back to PwdRec
When I try to access the CAX80 at 192.168.1.1 it reverts back to 192.168.1.1/PwdRec_index.htm. The only way I can get rid of this is to reboot, but that becomes annoying over time. Any help would b...
tobiasrubin
I have the latest FW.
Doesn't matter what browser is used.
Yes I tried clearing history, cache, etc.
Nothing seems to work but a reboot, and then in a week or so it happens again.
Dec 05, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
I've not seen this with my CAX80 and using MS Edge or Opera. I did ensure that the password manager for the browsers were cleared one time that I tried to log in with a browser that was using a incorrect saved PW. Once I cleared this, have not seen this again.
- tobiasrubinDec 05, 2022AspirantYes I have performed a complete factory reset and eventually the problem comes.
- tobiasrubinDec 05, 2022AspirantYes I have performed a complete factory reset and eventually the problem comes back.
