tobiasrubin
Dec 05, 2022Aspirant
Unable to log into CAX80 it reverts back to PwdRec
When I try to access the CAX80 at 192.168.1.1 it reverts back to 192.168.1.1/PwdRec_index.htm. The only way I can get rid of this is to reboot, but that becomes annoying over time. Any help would b...
My_Username
Dec 05, 2022Apprentice
Mine did this recently as well, I am running 2.1.5.2. It started after a short term coax disconnect for a wiring re-route. It has been up several days since the factory reset and fresh setup from scratch. I'll start a new thread if that changes.
It seems like it's always something with this thing.
IMO the CAX80 is just a hot mess...
Dec 06, 2022Guru - Experienced User
I know this sounds stupid but are you hitting the password requirements when you set it up?
It forces users to change the password when they don't hit minimum requirements.
required:
10 characters that are at least:
1 upper case
1 lower case
1 number
1 special character
- tobiasrubinDec 06, 2022Aspirant
You bring up a great point regarding password requirement and yes I believe I am hitting on all of Netgear's password requirments.
- plemansDec 06, 2022Guru - Experienced User
what happens if you try using the modem ip address? 192.168.100.1
Same result.
